usbuirt plugin
Help
Postby JPRosiak on Wed Jun 22, 2005 2:03 am
I need to be able to send IR Codes as well as receive IR codes. I want my remote to control my Home Theater PC, but I can't get the USBUIRT to receive signals.
I want to use my MX-500 remote to control Xlobby. How do I do this?
-Joe
JPRosiak
Postby rika on Wed Jun 22, 2005 5:48 am
rika
remove device usburit plugin
Postby jimgarrard on Fri Oct 13, 2006 8:23 pm
I have creted new devices in the usburit plugin and needed to cleal up a bit. How do you remove old devices?
jimgarrard
Re: remove device usburit plugin
Postby sharp_1 on Sat Oct 14, 2006 2:38 am
jimgarrard wrote:I have creted new devices in the usburit plugin and needed to cleal up a bit. How do you remove old devices?
Go into your xLobby folder and open the IR folder then codes folder then you will see your device.xml file...just delete the devices you don't need.
sharp_1
Previous
