Can anyone help on the crashes?
should I post in the Bug section?
Moderator: jowaldo
KCS.xAP.Framework.xAPException: The xAP message value is malformed
No part of the address value may contain space characters
at KCS.xAP.Framework.Message.xAPAddressBase..ctor(String address)
at KCS.xAP.Framework.Message.xAPTargetAddress..ctor(String target)
at xAPSpace.xAP.Execute(String command)
at xlobby2.Command.Run(Control control)
at xlobby2.Setup.button56_Click(Object sender, EventArgs e)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
xlobby2
Assembly Version: 1.0.2098.28537
Win32 Version: 1.0.2098.28537
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xlobby2.exe
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
XPluginSDK
Assembly Version: 1.0.2020.31144
Win32 Version: 1.0.2020.31144
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/XPluginSDK.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Runtime.Remoting
CodeBase: file:///c:/windows/assembly/gac/system.runtime.remoting/1.0.5000.0__b77a5c561934e089/system.runtime.remoting.dll
CDEX
Assembly Version: 1.0.1685.4787
Win32 Version: 1.0.1685.4787
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/cdex.dll
xusbuirt
Assembly Version: 1.0.1767.29466
Win32 Version: 1.0.1767.29466
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xusbuirt.dll
xAP-Xlobby
Assembly Version: 1.0.2121.36041
Win32 Version: 1.0.2121.36041
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xap-xlobby/xap-xlobby.dll
xAPTransport
Assembly Version: 1.2.9.2
Win32 Version: 1.2.9.2
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xAPTransport.DLL
KCS.Utilities
Assembly Version: 1.1.2.1
Win32 Version: 1.1.2.1
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/KCS.Utilities.DLL
xAPMessage
Assembly Version: 1.2.9.12
Win32 Version: 1.2.9.12
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xAPMessage.DLL
XoapWeather
Assembly Version: 1.1.1729.14788
Win32 Version: 1.1.1729.14788
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xoapweather/xoapweather.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
ldwwifuf
Assembly Version: 0.0.0.0
XWeather
Assembly Version: 1.0.1855.39961
Win32 Version: 1.0.1855.39961
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xweather/xweather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/Interop.Shell32.DLL
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/AxInterop.SHDocVw.DLL
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/Interop.ActiveHomeScriptLib.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
enabled.
For example:
<configuration>
</configuration>
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.ptrinchi wrote:No problem Richard, with the xAP3 version (last one) you have the ability to send every kind of xAP messages you want to every xAP modules on your network.
You have also the ability to give indication on witch messages Xlobby will take information for displaying states, texts or images.
ptrinchi wrote:Is there anyway to make the 0 - 100 png files generic instead device specific?
Yes, it's a good idea. If the png does'nt exist the plug could load a generic png file (without the device name) perhaps in the next version![]()
