DVD Profiler to Xlobby Import Utility
Re: DVD Profiler to Xlobby Import Utility
Postby jovial_mood on Wed Jan 16, 2008 9:12 pm
I wrote a document explaining how to use DXC.
http://www.jovialmood.st/dxc2_doc.htm
Cheers! :)
/Jovial
jovial_mood
Postby sharp_1 on Wed Jan 16, 2008 9:14 pm
NICE!!! Thanks Jovial
sharp_1
Postby nhasby on Mon May 19, 2008 1:15 am
I'm having troubles getting my movies to link up with my iso files. I can get the movies to link up without the utility but then I get black pictures and no dvd profiler info. When I use the utility it links them all up to a video_ts file that doesn't exist. Can someone please help.
nhasby
Postby jovial_mood on Thu May 22, 2008 3:39 pm
If using DXC utility, please post or mail me your dxc2.ini file (it's an ordinary text file).
I would also need to know the local search path to at least one of the iso files in question.
jovial_mood
Postby hjackson on Fri Jul 03, 2009 1:42 pm
I'm still confused. If my movies are stored as ISO files, how do I configure DXC Movie Search Setup?
hjackson
hjackson
Postby jovial_mood on Sat Jul 04, 2009 10:06 am
If your movies are stored as ISO files, either the files themselves or the directories they reside in needs to be named the same as the movie titles or sort titles. Under DXC file search options you can select to match titles or sort titles.
Example 1: the directory names are the same as the movie titles
C:\Movies\Slumdog Millionaire\movie.iso
C:\Movies\Gothika\movie.iso
C:\Movies\Gran Torino\movie.iso
C:\Movies\Van Helsing\movie.iso
To find these movies you would add C:\Movies\ as search path and mark "Select first file" like this:
http://www.jovialmood.st/images/dxc_doc/isoexample1.gif
Example 2: the file names are the same as the movie titles
C:\Movies\Slumdog Millionaire.iso
C:\Movies\Gothika.iso
C:\Movies\Gran Torino.iso
C:\Movies\Van Helsing.iso
To find these movies you would add C:\Movies\ as search path and omit the file name like this:
http://www.jovialmood.st/images/dxc_doc/isoexample2.gif
Using these examples the search path list will look like this:
http://www.jovialmood.st/images/dxc_doc/isoexamplelist.gif
As you can see in the list the first search will try to match directory names to movie titles. If there's a matching directory name the first file found in that directory will be considered as a search hit.
The second search in the list indicates that file names will be matched against the movie titles.
I hope this help.
// Jovial
jovial_mood
Postby hjackson on Sat Jul 04, 2009 11:19 pm
It still isn't working for me. When I check the database, it still shows the "video_ts.ifo" parameter but not the path.
hjackson
hjackson
Postby hjackson on Sun Jul 05, 2009 2:23 am
To give you more info, a typical ISO file on my system looks like this: "\\Htpc\p\Movies\PREDATOR 2\PREDATOR 2.ISO".
P represents my server's external drive, of which I have several. Htpc is my server on my network.
hjackson
hjackson
Postby jovial_mood on Sun Jul 05, 2009 1:19 pm
If you open the file xx\dxc_cache\dxc_hits.xml (xx is the path to where dxc2.exe is) in a text editor (like notepad), are there any items between the cache tags?
If not, please open one of the dxc_nn.xml in the same directory (nn is the number of the listed search path, numbered from 0 and up). Do you see the actual search path that should render a search hit in this file?
jovial_mood
Postby hjackson on Sun Jul 05, 2009 10:42 pm
Jovial_Mood, since my last post I checked the "search all subdirectories" box, and it was definetly doing more on the conversion process. but at the end of the conversion it would error out with an "error 91" message.
The first message reads:
"Error while converting DVD Profiler -> Xlobby Database
Error code:91
Object reference not set to an instance of an object.
Please check your DXC Settings..."
The next message reads:
"Error counting movies in DVD Profiler Database.
Error code:91
Shutting down DXC..."
When I check dxc_hits like you asked I see that there are items and matches and the path files are found. For example:
<item>
<title>ALADDIN</title>
<c_number>381</c_number>
<match>ALADDIN</match>
<path>\\Htpc\M\Movies\ALADDIN\ALADDIN.ISO</path>
<search>#3 | \\Htpc\M\Movies\</search>
</item>
Am I having a problem because I have more movies listed in DVD Profiler than I actively do on my server (this would be due to hard drives crashing :x ) ?
hjackson
hjackson
Postby jovial_mood on Wed Jul 08, 2009 6:07 am
Those two error 91 messages would be typical if DXC can't read the input file properly. You might want to export a new Collection.xml to make sure it's ok. Also, make sure you're using the latest version of DVD Profiler (v3.5.1 Build 1252).
If you're only getting these errors when using the search function and not with the search function disabled, one or more of your titles in your DVD Profiler xml might be missing the CollectionNumber tag.
Further more, I found a bug in how DXC handles box sets when the search function is enabled. I will make a new version of DXC available soon.
jovial_mood
Postby jovial_mood on Sat Jul 18, 2009 5:40 pm
A new version is now available for download:
DXC v2.1 http://www.jovialmood.st/files/dxc/dxc21.zip
// Jovial
jovial_mood
Postby Carlos Delgado on Fri Feb 19, 2010 12:46 am
jovial_mood wrote:I wrote a document explaining how to use DXC.
Cheers! :)
/Jovial
Carlos Delgado
Postby Carlos Delgado on Fri Feb 19, 2010 1:17 am
Jovial
Can you help me with this question.
Your app is working great except?
That it is overwriting the setting for Event (Assign an individual event to a database item)
When I assigned and event to an individual item everything is fine until I use your app then it overrites the setting I just made, can you tell me how to prevent your app from removing this setting.
Carlos Delgado
jovial_mood wrote:I've just finished writing a new utility which has the main purpose of importing DVD Profiler data into an Xlobby compatible database. Even though you can import some tags with Xlobby's own import function I believe this utility gives you a little more control over which information should be imported and which shouldn't.
The latest version of the utility can be downloaded from the address:
v2.1 (18 July 2009) http://www.jovialmood.st/files/dxc/dxc21.zip (90k)
(Only for use with DVD Profiler v3.x exported XML file)
// Jovial
Carlos Delgado
Postby Carlos Delgado on Fri Feb 19, 2010 5:49 pm
Jovial
YES. I have been using the latet version but I still have the same question:
Carlos Delgado
Carlos Delgado wrote:Jovial
Carlos Delgado
// Jovial
Carlos Delgado
