XVis : a visualization plugin www
Postby badubo on Sat Jan 07, 2006 11:46 pm
http://france.xlobby.com/plugins/Screen03.JPG
This plugin allows to display a graphical spectrum and visualization window in xlobby, independantly of the player used
It is based on the BASS library
http://france.xlobby.com/plugins/XVis1_0.zip
XVis 1.0
Badubo French XLobby Team
Introduction
This plugin allows to embbed a graphical spectrum and/or a visualization window directly in a xlobby screen.
It doesn't rely on the player used (winamp or foobar) but use diretly the output of the sound card.
It is based on the BASS libray (www.un4seen.com)
Features
- compatible with sonique visualizations  (not WinAmp or foobar visualizations)
- 12 types of different spectrum
Requirement
-You must have a sound card with a recording control that record the output of the card (often called stereo mixer or record master)
-use the last version of xlobby (http://www.xlobby.com/xlobby2.zip).
Installation
-Copy the content of the zip file in the xlobby directory
(The content of the subfolder "plugins" must be in the "plugins" folder of xlobby
- Open the configuratin dialog box of te plugin (Setup/plugins/XVis: configuration) and select the device and recording control to use
Utilisation
A skin, "XVis" is given as example for the use of all methods
The window where you want to display the spectrum must have as ID : XVis_Spectrum_screenname
The window where you want to display the visualization must have as ID : XVis_Visual_screenname
with "screenname" : the name of the current screen
Visualizations
You can find compatible visualizations there :
http://support.xmplay.com/Visuals_index.html?0&20
http://www.ultraplayer.com/
The dll's (.uvs, .svp) of visualizations MUST be installed in the "vis" subfolder of /plugins/XVis
Badubo
Member of XLobby FR Team
badubo
Postby GFORCE on Sun Jan 08, 2006 7:41 pm
Hey badubo,
Is there anyway that you can make something for milkdrop to use?
I am using Wnamp Visualation's to show a Spectrum on my VFD which is on the front of the Media Center,
But i would really like some sort of onscreen Visualisation.
Is there something you can recommend as i really like Milkdrop and the XVis doesnt show the aspect ratio correctly on my plasma?
GFORCE
Postby badubo on Sun Jan 08, 2006 8:07 pm
actually, no.
What do you mean by "doesnt show the aspect ratio", it embed the visualization in the text zone you create
Badubo
badubo
Postby GFORCE on Sun Jan 08, 2006 8:09 pm
there is nothing like milkdrop that is standalone?
GFORCE
Postby badubo on Sun Jan 08, 2006 8:19 pm
I don't know, the visualizations working with xvis are enough for me, so I didn't search for other kind of vis.
Badubo
badubo
Postby GFORCE on Sun Jan 08, 2006 8:28 pm
i tried your plugin, but there is a problem.
If i am going thru the visual's they freeze and wont respond to any command
GFORCE
Postby badubo on Sun Jan 08, 2006 8:58 pm
Is the spectrum working?
What kind of computer do you have? They require a big amount of CPU
Badubo
badubo
Postby GFORCE on Sun Jan 08, 2006 9:37 pm
AMD 64 X2 4800+
there is plenty of power and ram at its deposal.
both of them lock up.
GFORCE
Postby badubo on Sun Jan 08, 2006 9:56 pm
With the XVis skin or another one?
Did you configured the sound card?
I use the bass library, I don't know if it work with AMD 64 based computers
Had the plugin worked once? :
So, I guessed that at least it was working.
Badubo
badubo
Postby dalanik on Sun Jan 08, 2006 10:30 pm
Great plugin, but I have one problem - Start and Stop work exactly the same for me... So if I enter screen and it is set to auto start, then press stop (it stops) and exist the screen (and then it auto-stops), it actually starts again in the main menu....
Any way to make start only start and stop only stop?
D.
Postby badubo on Sun Jan 08, 2006 11:50 pm
I don't understand what is "auto start"?
If you leave a screen with a vis started, if the plugin doesn't found a vis zone in the new screen, it will hide the vis. And as soon as you return in a screen with a vis zone, it will restart the vis (but may be I don't understand your problem.
In the xvis skin, start and stop work correctly ?
Badubo
badubo
Postby badubo on Mon Jan 09, 2006 9:59 am
@GFORCE :
I found a potential dead lock, may be it's your problem, I will correct it this evening and upload the pack
Badubo
badubo
Postby badubo on Tue Jan 10, 2006 12:05 am
Update : same link
Badubo
badubo
Postby milanp on Tue Jan 10, 2006 10:28 am
It seems to work OK but only one small bug:
Visual_stop works the same as visual_toggle
it stops the visualzation if it is running and starts the vizualization if it is not running.
milanp
Postby badubo on Tue Jan 10, 2006 10:45 am
Effectively, I corrected.
Badubo
badubo
