INSTEON - HVAC set-up
Heating, ventilating, and air conditioning systems
Postby vaporhat on Thu Jun 17, 2010 7:02 pm
Can someone post up a smaple of thier Insteon HVAC set-up?
-3RiC
Re: INSTEON - HVAC set-up
Postby vaporhat on Mon Jun 21, 2010 12:38 pm
Does anyone use HVAC control? anyone... anyone??
Where do I begin.. someone please just point me in the correct direction...
-3RiC
Postby smarty on Mon Jun 21, 2010 3:55 pm
Wish I could assit, but all my insteon stuff is set up w/ PowerHome, not with Xlobby. Without indepth link management tools, Insteon w/Xlobby could be very cumbersome. I will be watching this thread....hope someone else chimes in.
smarty
Postby wesblack on Tue Jun 22, 2010 4:11 am
I will post some details, screenshots before the end of the week.
Postby wesblack on Wed Jul 14, 2010 5:43 pm
xLobby controlling 10 Separate Zones of HVAC using Insteon Technology
xLobby xController setup using the Insteon Service
The device name "thermostat" must appear first in order for the service to communicate with the Insteon PLM properly.
Hardware:
Insteon 2443 Wireless Access Point
Insteon 2441v Wireless Thermostat Adapter
venstar thermostat.jpg (8.41 KiB) Viewed 3311 times
Venstar 7 day programmable thermostat with Insteon 2441v Wireless Thermostat Adapter attached
• Save energy and money on bills by remotely controlling your thermostat
• Everything you need: Includes Venstar T1800 Thermostat plus INSTEON Thermostat Adapter
• Works with heat/cool and heat pump systems
Product Summary
Turn the temperature up or down from anywhere in the house! INSTEON Thermostat Adapter allows you to adjust your thermostat from any INSTEON-compatible controller.
Specifications
Thermostat
Brand:
Venstar
Dimensions:
4 3/4" x 4 1/4" x 1 1/8"
Control Stages:
2 heat, 1 cool
Compatible Systems:
Heat/cool; heat pump
Approvals:
UL listed, FCC Compliant
Adapter
Brand:
Smarthome
Range:
150' (line of sight)
Frequency:
915 MHz
Status LED:
1 Green LED (normally on)
Setup Memory:
Non-volatile EEPROM
Return to HVAC
