95-1070 xLobby IR Remote
Postby wesblack on Sat Jul 12, 2008 5:41 am
All the keys on xLobbys remote control can be re-configured / mapped in xLobby Clients or Servers to create any custom or macro event.
Standard Button Commands
xLobby F2 Setup Menu
Re: 95-1070 xLobby IR Remote
Postby Jay on Fri Aug 29, 2008 9:24 pm
I've been using the remote to navigate XL, switch cameras and control X10 functions.
It's great!
But how do you assign an event to the IR remote?
I went into the plugin in setup and had it learn to switch my TV on and off thru my blaster. I assigned the learned code to remote key 0. I can hit transmit and the plugin will operate the TV fine thru the blaster. I hit Set after the test and have an ID.
How do I define an event to have the remote key 0 do the same?
Postby wesblack on Fri Aug 29, 2008 9:50 pm
Jay,
Please call me.
Postby Jay on Fri Aug 29, 2008 10:16 pm
Wes, you're getting ready for CEDIA.
I'll call when you get back.
Postby Jay on Sat Aug 30, 2008 11:23 am
Please disregard. It was too simple. Got it :)
Return to xLobby Remote Control Devices
