build 3.9166.25, Hulu, remote.
Postby Jay on Tue Jun 16, 2009 9:59 pm
"The xLobby remote control now works with Hulu, users can modify the remote control triggers for Hulu to suit there specific remote control."
Is that the 95-1070 rev. 1 remote?
Nothing happens. I haven't played with triggers yet, if that's what I need to do, no problem. Just need clarification.
Re: build 3.9166.25, Hulu, remote.
Postby wesblack on Wed Jun 17, 2009 4:07 am
Jay,
So when you launch Hulu from xLobby the xLobby remote does not work is this correct....?
Postby Jay on Wed Jun 17, 2009 12:19 pm
Correct. Tried it on 2 machines. Checked remote rev. 1 enabled. No navigation, pause, stop, volume, etc.
Postby wesblack on Thu Jun 18, 2009 5:51 am
Jay,
Are both machines Vista or XP....?
Postby Jay on Thu Jun 18, 2009 12:09 pm
Vista.
I meant to add that to the post.
Postby stevenhanna6 on Thu Jun 18, 2009 11:25 pm
it's probably using your old "xLobby Remote.xml" eventgroup file, you need to overwrite that file it controls the hulu app...it in the root eventgroups folder.
xLobby Remote.xml
(47.58 KiB) Downloaded 315 times
Postby Jay on Fri Jun 19, 2009 12:00 am
Thanks Steven. That was it.
Was looking at the skin level for the change.
Return to xLobby Remote Control Devices
