Insteon - Smartlinc / Powerlinc
Product and media content integration into xLobby
Postby vaporhat on Tue Aug 03, 2010 5:37 pm
As far as XL is concerned, are these two Insteon products the same in functionality?
http://www.smarthome.com/2412N/SmartLin ... ler/p.aspx
http://www.smarthome.com/2414U/PowerLin ... ice/p.aspx
I currently have the 2414U and it works fine. But i am looking to use Smartlinc iPhone interface.
-3RiC
Re: Insteon - Smartlinc / Powerlinc
Postby wesblack on Thu Aug 05, 2010 2:53 pm
The 2413S is the most reliable interface module to use with xLobby. There is no xLobby support for the 2412N Module at the moment.
The 2413S and the 2414U will work fine with xLobby.
http://www.smarthome.com/2413S/PowerLinc-Modem-INSTEON-Serial-Interface-Dual-Band/p.aspx
Return to Apple-Mac Product Integration
