xweather help
xweather help
Postby dhcf23 on Thu Oct 15, 2009 7:43 pm
I currently use Xoapweather but was looking into using something similar to Rika's weather skin and having some weather backgrounds as well as the normal icons for the the forecast and to do that is looks like the easiest way is to use both plugins.
So my problem is when I try to use xWeather it just clocks...it says please wait while loading and then never loads anything for weather. When I go to the plugin and try to set anything up it does not have anything in it to choose as far as regions or locations. Can anyone give me something to try to get it to work? I have downloaded the latest plugin from the downloads section in xlobby.
dhcf23
Re: xweather help
Postby dhcf23 on Mon Oct 19, 2009 3:56 am
Anyone having problems with Xweather besides me, if not how do you add or edit the cities or forecasts. Everything is blank for me.
dhcf23
Re: xweather help
Postby Marbles_00 on Mon Oct 19, 2009 12:57 pm
Did you get the most recent version of the plugin? It was offered by Steven to the newer version of Xlobby, but works just as well with the old one. I don't have a link but you should be able to find the thread by using the search.
*EDIT*
Found the thread post by Wes here:
viewtopic.php?f=6&t=6335&p=45169&hilit=+xweather#p45169
Re: xweather help
Postby dhcf23 on Mon Oct 19, 2009 6:08 pm
I was using the latest version that is downloaded by the free xlobby in the downloads section, so it is probably not the same one. I will give this new one a try...thanks for the link.
dhcf23
Re: xweather help
Postby dhcf23 on Tue Oct 20, 2009 1:54 am
xweather is now working after updating to the ;atest plug in, thanks again. There is one issue down!!
dhcf23
Return to Support
Users browsing this forum: No registered users and 8 guests
