mapping network drive
title says it all
Postby dalanik on Mon Mar 05, 2007 9:55 pm
I dunno if this would be interesting to anyone, but I had this problem for a long time, since I use a network drive for movies.
The thing is, that sometimes, if I turn on HTPC and the NetDrive remains off, and I turn it on AFTER HTPC boots, it still sees network drive as offline. Connected, but offline. And if you ask why would I use drive instead of UNC path, it's ismply because then I can open movies from Zoom. If I used UNC path, there's no way to open files from Zoom's navigator.
Anyway, for a long time I used this script which simply maps drive. It is VBS, since .NET doesn't support drive mapping natively.
' *** VisualX *** Created by Dalibor Lanik 2006
Option Explicit
Dim WshNet
Set WshNet = WScript.CreateObject("WScript.Network")
On Error Resume next
WshNet.MapNetworkDrive "V:", "\\Netcenter01\Files"
Wscript.quit
This maps drive if it's not mapped, but it still fails to open it, and the drive remains offline when I run Zoom.
I eventualy had to run Total Commander and open drive V: (my net drive) in order to make it online.
I came to this XScriptNG solution which is included in my Visual GM skin, but not everyone may notice it there. It maps drive, and then does DIR, which makes it online.
' *** VisualX *** Created by Dalibor Lanik 2007
Imports System.Diagnostics
Module Script
Public Sub Main()
Dim nri As Integer
Dim StrPath, ContentItem As String
Dim myProcess As Process = new System.Diagnostics.Process()
StrPath = "V:\"
myProcess.StartInfo.FileName = "net"
myProcess.StartInfo.Arguments = "use v: \\Netcenter01\Files"
myProcess.StartInfo.WindowStyle = System.Diagnostics.ProcessWindowStyle.Hidden
myProcess.Start
myProcess.WaitForExit()
myProcess.Close()
nri = 0
If (System.IO.Directory.Exists(StrPath)) Then
ContentItem = Dir(StrPath + "*.*")
Do Until ContentItem = ""
nri = nri + 1
ContentItem = Dir()
Loop
End If
End Sub
End Module
Hope someone finds it useful.
D.
Postby cmhardwick on Tue Mar 06, 2007 3:25 am
That's fairly typical of windows I've found. I have several mapped drives on my work laptop. When I logon at home of course, it can't reconnect and shows them offline, even after I connect to the company network via VPN. If I open the drive via explorer, it "wakes up" and sees the drive as online. Just attempting to open a file on the share from a shortcut or "recent documents" list fails.
Great little fix dalanik!
Postby wesblack on Tue Mar 06, 2007 5:39 am
Steven and I have talked about this in great detail. This is an important feature we want added to the Xlobby product line. We hope to add something into the Xlobby Client, Server setup that helps deal with mapped drives, etc. Thanks for the script. Steven and I will look at it.
Wes
Postby rhinoman on Tue Mar 06, 2007 9:04 am
I used to have the issue too, its because as the wuindows desktop comes up iot hasn't finished loading the network driver and so the drive doesn't map.
I got round it by using a batch file and wait.exe. The wait.exe was downloaded by microsft and the batch file contained the following
wait 10
net use M: \\server1\media /persistent:no
You can just repeat the line for extra drives.
John
Xlobby-Server: AMD64x2 4400+, 1gb ram, MSI NF4, RME 96/52 HDSP, 2*aeb8o for 8 zones feeding amps with long speaker runs, 2 touchscreen's and 2 Dell X5 PPC's. "Unraid" media storage.
rhinoman
Postby S Pittaway on Tue Mar 06, 2007 11:18 am
i use
REM WAKE THE SERVER
PING -N 1  -L 1  server1
DIR \\server1\media
REM DELETE THE OLD MAPPING
NET DELETE M:
REM RE-MAP THE DIRVE
NET USE      M: \\server1\media /persistent:no
normally, simply doing a PING and a DIR will wake it if the drive is already mapped..
Postby dalanik on Tue Mar 06, 2007 1:13 pm
S Pittaway wrote:i use
REM WAKE THE SERVER
DIR \\server1\media
NET DELETE M:
Yes, but I wanted something that wouldn't pop-up the DOS window :-)
D.
Postby S Pittaway on Tue Mar 06, 2007 1:19 pm
on the os:execute event there is an hide option... :)
Postby jowaldo on Tue Mar 06, 2007 4:38 pm
S Pittaway wrote:on the os:execute event there is an hide option... :)
That hide option is the best, cuz doin things like that in DOS is easy compared to any scripts.. at least for me ;)
Check out Jowaldo's Skin
Return to Tips and Tricks
