Does anyone use SS Beyond TV and need an integration writeup
title says it all
Postby kuntakintay on Fri Apr 30, 2004 9:59 pm
Anyone anyone? If I am the only loser that uses it, I aint gonna waste my time documenting. Pretty simple config, but may be a help to document it...
Toby :lol:
kuntakintay
Postby AirPost on Sat May 01, 2004 1:09 am
Sure, fire away. Are you talking about the command lines that go straight to live tv, recorded shows and tv guide?
AirPost
Postby kuntakintay on Mon May 03, 2004 2:36 pm
AirPost wrote:Sure, fire away. Are you talking about the command lines that go straight to live tv, recorded shows and tv guide?
Yep, and built a menu for the colby skin for it... Ill work on a writeup this week and post in the documentation section.
kuntakintay
Postby totoz on Mon May 17, 2004 7:15 pm
Very useful! May you send us a link to your TV page? looks very interesting! I'm in the process of evaluate SageTV vs BTV, but the latter is better if integrated in Xlobby (less work to do :) )
.toto
totoz
BeyondTV3 integration with Xlobby
Postby Alpha179 on Wed Jul 21, 2004 6:03 am
I would definately like some help integrating BeyondTV3 into xlobby.
Alpha179
Alpha179
BTV and XLOBBY ...
Postby kolemieux on Fri Oct 08, 2004 2:20 am
Anyone able to make a nice marriage here? BadaBing did a nice job of doing this with SageTV - is anyone looking to do it with BTV?
kolemieux
Postby Alpha179 on Fri Oct 08, 2004 4:08 pm
here is a list of command line options that I have found
tested and working well:
/mode FS
/mode Windowed
/mode TRUEFS
/mode FAKEFS
/startscreen tv
/startscreen library
/startscreen guide
not tested
/startscreen top
/startscreen home
/startscreen livetv
/startscreen epg / jobs
/startscreen epg / recordings
/closegui
windowed mode options only
/width (value)
/height (value)
/xpos (value)
/ypos (value)
/border [on/off]
hope these help.
And as usual, use at your own risk as I am not responsible :)
Alpha179[/b]
Alpha179
Postby Jibril on Sat Oct 09, 2004 1:15 am
The 3.5 version of BTV was released this morning. It new executable and parameters are:
BTVD3DShell.exe (opens to last mode it was in)
BTVD3DShell.exe /displaymode:fs (Full Screen Mode)
BTVD3DShell.exe /displaymode:windowed (Windowed Mode)
I did figure out how to emulate the way Beyond Media integrates BTV. Here's the way I setup Xlobby with it:
1. Set Btv to start in background.
2 Create one event to both execute an execute command for BTVD3DShell.exe and a show window command. For show window the class name is Streamzap.WM.D3D and window name is Beyond TV. Then attach the event to a button.
3. In Girder, add a minimize window command with BTV as its target and learn it to a key on your remote.
4. Turn off the Exit Viewscape option in BTV's web admin. (you won't need it and Beyond Media runs it this way, but ths is optional)
The only difference with Beyond Media and this is that the escape key, when in the main window of BTV, will minimize BTV and go back to BM. Here it takes a key on you remote. Other than that, it looks like it works the same.
Later,
Jibril
Jibril
Postby buymeapc on Wed Mar 22, 2006 5:54 pm
I know Sage TV has been integrated, but has anything ever happened with Beyond TV integration? :?:
buymeapc
Return to Tips and Tricks
