Girder2Xlobby plugin and Convert_Girder2xlobby_to_GML
title says it all
Postby badubo on Tue Jun 01, 2004 8:49 pm
Hello,
Here is an alpha version of 2 tools that can allow to easilly control your existing skin with girder and a remote.
you can dowload it at
http://users.skynet.be/fa426932/temp/girder2xlobby.zip
readme.txt is included in the .zip
The principle is quite simple, it parses the xml files in the both eventgroups directories and create "sendmessage" triggers for events that don't have one.
Then it fills a .ini containing all these events and the associated wparam.
You can use it from girder as any other plugin by simply select the event (that owns the same name as in xlobby)
You will find also a vbs script made by jbt_f that creates a xlobby.gml file that you can use directly.
Note : if you don't see the settings dialog box, use alt-tab
Comments are welcome
badubo
Postby gravy on Wed Jun 02, 2004 1:04 am
Early testing indicates this is GREAT! Fantastic job.
gravy
Postby QTips on Wed Jun 02, 2004 6:50 pm
Working here to :)
Now I just have to create a superduper GML in girder one day I'm less lazy than today
P4 3Ghz+,Asus MB,768RAM,Nvidia 6600 GT,WinMCE 2005,FireDTV DVB-C ,Panasonic AE700 Projector ,Dell Axim Pocketpc
http://qtips.mine.nu/
QTips
Postby lar282 on Wed Jun 02, 2004 7:26 pm
GREAT JOB.
worng id
Postby jpoveda on Mon Jun 07, 2004 6:53 am
Hi,
I tested your progarm and it's really cool. Only a thing. I have other girder plugin with same id, so I can't start both plugins. Would It be possible for you to change it to other?.
Thank you very much.
jpoveda
Postby badubo on Mon Jun 07, 2004 11:00 am
Hi,
Yes, of course, I already asked the girder staff and they gave an official plugin number.
I will introduce it in the next version
Badubo
Member of XLobby FR Team
badubo
Postby badubo on Mon Jun 07, 2004 2:59 pm
New version : same link
see the readme.txt for information
Badubo
badubo
Postby jpoveda on Thu Jun 10, 2004 8:33 am
Thanks badubo,
Have you tried to put exec parameters double quoted in parameters field?
jpoveda
Postby badubo on Thu Jun 10, 2004 8:45 am
not yet,
I 've many problems to deal with. And didn't had time to test this trick. But I will test it ASAP
Badubo
badubo
Postby Arthur on Sun Jun 13, 2004 2:55 pm
An error:
Could not load: c:\program files\girder32\plugins\girder2xlobby.dll
occurs :(
I'm using girder 3.2, win98. It does not matter if I disable other plugins from loading.
its a pitty
Arthur
Arthur
Postby Twit on Sun Jun 13, 2004 3:07 pm
Arthur,
You need some kind of ms dll in your widows dir (cannot remember which one).
You did put xerces-c_2_5_0.dll in you win/sys32 directory?
Coz it works great for me
Later
Simon.
Twit
Postby badubo on Sun Jun 13, 2004 3:25 pm
Hi,
you have to copy the cerces dll in system32
you have also to have one MS dll : mscvr70.dll in your system32
http://www.dll-files.com/dllindex/dll-f ... ml?msvcr70
download the .zip, and copy the MSVCR70.dll in your suytem32 directory.
Shutdown girder and restart it
Badubo
badubo
Postby Arthur on Sun Jun 13, 2004 4:15 pm
Thanks! I was completly focussed on the girder part of it. I had put the dll files into system instead of system32. :oops:
Well, I'm on the roll again!
Arthur
Arthur
Rules
Postby jpoveda on Mon Jun 21, 2004 6:52 am
Hi Badubo
I don't understand very well how rules works. Could you explain it me more extensive?.
Thanks a lot.
jpoveda
Postby dgemily on Mon Jun 21, 2004 7:05 am
hy jpoveda,
here : http://france.xlobby.com/telecommande.htm you can find a tutorial by C-moi about the plugin, it's in french but there are a lot of screenshots, may be it's can help you...
later.
Releases from the French team
dgemily
Return to Tips and Tricks
