Pre-Release not talking to Girder
Postby memoe on Mon Oct 29, 2007 5:09 pm
Steven,
I know you are not touching the prerelease versions, but I believe I've found a significant bug. The latest build, 2.0.7291.1 does not send messages to Girder (Girder runtime 4.0). At the very least, this is a bug that should be fixed in XL3.
memoe
memoe
Re: Pre-Release not talking to Girder
Postby wesblack on Mon Oct 29, 2007 5:17 pm
Memoe,
We will look into the issue and advise.
Postby badubo on Mon Oct 29, 2007 6:14 pm
As far as I remember, you need a dll called event.dll in the xlobby directory.
This dll comes from the girder package ans this is possible that it needs to be updated (the one provided with xlobby is quite old)
take a look in your girder package if you find it and copy it in the xlobby directory
badubo
Postby memoe on Mon Oct 29, 2007 6:50 pm
badubo wrote:As far as I remember, you need a dll called event.dll in the xlobby directory.
Badubo!
As always, you are correct! A quick search turned up:
In the latest pre-release:
11/13/2002  19:47          45,056  gireventlib.dll
In my Free XL directory:
4/28/2006  15:48           49,152  gireventlib.dll
Copied from Free XL to Pre-release, and it worked!
memoe
