I really have used the search function, but it hasn't helped me so far. I'm running the very latest version of Xlobby supposedly (from Steven's sticky thread in the Announcements forum):
1. First I had a usbuirt.dll2 file in the plugin folder, but nothing showed up in the IR plugin drop-down menu -- so I went to the Download tab and downloaded/installed the plugin, and now I also have a usbuirt.dll file there -- now the plugin appears in the list, but how do I know I'm running the right version, and what's with the .DLL and .DLL2?
2. I can see codes appearing in the IR plugin window when I point a remote at it, but can someone outline the exact steps for learning commands? I've been pressing "set" to turn the box green & capture the code (I guess?), but what the heck do "transmit" & "learn" do? Pressing the learn button pops up a progress bar that never moves (and also appears to stop the USBUIRT from lighting up for some reason), so then I abort. The process doesn't seem intuitive, and I have no idea what I'm doing here.
3. How can I quickly test what I've supposedly learned? I was hoping I could from the same screen in setup transmit the just-learned command, to at least make sure it works, but so far I haven't been able to figure that out.
4. And lastly, can someone please give me a detailed step-by-step of how to assign my (hopefully) learned IR command to an existing button in a skin (or also a new button)? I'm a complete newbie with the event manager/skin editor, and know absolutely nothing.
So far, searching the forum for all this info has not led to me an idiot's guide to capture IR commands and assign them to things...
Thanks so much for your help,
Brent
