Ripping and cataloging from within Xlobby
Postby grafpaper on Mon Sep 05, 2005 5:01 pm
I must say, I discovered Xlobby this morning and it is exactly what I was looking for; a way to organize and catalogue my DVD collection.
My only question is, are there any plugins available that would allow me to rip and catalogue from withing Xlobby?
grafpaper
Postby lar282 on Mon Sep 05, 2005 5:44 pm
there is a dvd rip plugin if I'm not mistaking.
http://www.xlobby.com/forum/viewtopic.php?t=2336
even though the app is not developed anymore it should work.
Or just pick a ripping app that supports command line and set up an event to run it.
Postby grafpaper on Mon Sep 05, 2005 9:08 pm
yeah, I have that plugin, but it doesnt seem to integrate with Xlobby... like there is no button or prompt when i put in a DVD that asks if i want to rip. I guess that is what i'm looking for.
grafpaper
Postby kjheu on Tue Sep 06, 2005 2:21 am
That would be a feature of the skin you are using. I beleive that the Static skin has support for the DVD ripping plugin.
kjheu
Postby grafpaper on Tue Sep 06, 2005 2:54 am
Static skin seems to support what I'm looking for although it seems to be extremely buggy. It has a hard time getting video files to run in zoomplayer and it never detects a disc in my DVD drive. I'm not quite sure if its the skin or if its my fault, but im gonna try to work with it.
I am also not able to play music at all, in any skin i use. It says playing but then the timer always says 0:00/0:00 and i hear nothing. Any advice?
Thanks a lot in advance
grafpaper
Postby GFORCE on Tue Sep 06, 2005 3:56 am
you might have to edit the configuration file for the DVD Ripping Plugin, it might be looking for a CDRom with a different Drive letter!
What sort of Problems are you having with zoomplayer?
GFORCE
Postby grafpaper on Tue Sep 06, 2005 3:59 am
Only when i try to run files in zoomplayer from the Static skin, they just dont play.
Lol that and the fact i payed $28 to register it, its been nearly 12 hours and i have yet to receive and email with my code and instructions on how to use it :( .
grafpaper
Postby GFORCE on Tue Sep 06, 2005 4:45 am
have u set Zoomplayer to use a DVD Codec?
GFORCE
Postby GFORCE on Tue Sep 06, 2005 4:47 am
GFORCE
Postby lar282 on Tue Sep 06, 2005 6:04 am
grafpaper wrote: and it never detects a disc in my DVD drive.
Have u set the AUTO PLAY in xlobby to autoplay dvd:s? Press F2 and look for the option.
I think u post zoomplayer question over at the inmatrix forum cause it sounds like a zoom issue and not a xlobby issue. They are really good at zoomplayer and bligh is good at answing posts.
Also check out the help pages for xlobby, I think it was colby that wrote a really good paper on xlobby for beginners.
Postby rubbah on Tue Sep 06, 2005 6:12 am
welcome to Xlobby :wink: it can be tricky in the beginning but it's so worth it :D
rubbah
Postby grafpaper on Tue Sep 06, 2005 12:36 pm
yeah it seems like it. Tinkering with it to get what i want is a lot of fun. It about the journey not the destination.
grafpaper
