The primary benefit I saw was that I wanted my drives to spin down when I was not using them (configurable), which for movies is most of the time. I still store all music on the media server not the raid array which is in a seperate box. I also wanted to reduce noise.
Here is the component list I used:
ASUS A8N-VM CSM Mothboard with AMD Athlon 3200+ (any motherboard that will boot from usb will work)
Zalman CNPS7700-Cu CPU Cooler (very quiet)
3U Rack mount chassis designed for 8 3.5" disk trays
128mb USB Key
4 750gig
Unraid Pro (there is is free version that will give you 3 drives) I bought the pro for $69 than gives me 7 total.
http://www.lime-technology.com/wordpress/
No Monitor, mouse or keyboard is required after installation. The Array management is done via a browser. Here are some looks at that. Very simple to setup an operate. I can access the Array via mapping a network drive or FTP.
1 drawback is that the largest drive is reserved as a parity drive. That is on the roadmap to fix at some point.
